Transistorschaltung Simulation in LT Spice
Diskutiere Transistorschaltung Simulation in LT Spice im Lehrling und Studi Forum Forum im Bereich WEITERE ELEKTROTECHNISCHE BEREICHE; Hallo! Ich habe ein Problem mit meiner Transistorschaltung: transistorschaltung mit gate.png wenn ich das Gate weglasse, funktioniert das...
  1. #1 abharakadabra, 05.08.2025
    abharakadabra
    abharakadabra Neues Mitglied
    Hallo!
    wenn ich das Gate weglasse, funktioniert das Simulieren. Wenn ich es
    drinhabe, funktioniert es nicht. Die fehlermeldung ist:
    solver = Normal
    Maximum thread count: 16
    tnom = 27
    temp = 27
    method = trap
    Early termination of direct N-R iteration.
    Direct Newton iteration failed to find .op point. (Use ".option
    noopiter" to skip.)
    Starting Gmin stepping
    Gmin = 10
    Gmin = 1.07374
    vernier = 0.5
    Gmin = 0.180144
    vernier = 0.25
    vernier = 0.125
    vernier = 0.0625
    vernier = 0.03125
    vernier = 0.015625
    Gmin = 0.180144
    vernier = 0.0078125
    vernier = 0.00390625
    vernier = 0.00195312
    vernier = 0.000976562
    Gmin = 0.179749
    vernier = 0.000488281
    Gmin = 0
    Gmin stepping failed
    Starting source stepping with srcstepmethod=0
    Could not converge to DC with sources off!
    Starting source stepping with srcstepmethod=1
    Source Step = 3.0303%
    Source Step = 19.8864%
    Source Step = 19.9071%
    Source stepping failed
    Pseudo Transient failed in finding the operating point at 39.0473 µs.
    Trouble finding operating point....skipping operating point for
    Transient analysis.
    Changing Tseed to 9.76562e-08
    Changing Tseed to 9.76562e-10
    Changing Tseed to 9.76562e-07
    Changing Tseed to 9.76562e-11
    Changing Tseed to 9.76562e-06
    Changing Tseed to 9.76562e-12
    Changing Tseed to 9.76562e-05
    Changing Tseed to 9.76562e-13
    Changing Tseed to 0.000976562
    Changing Tseed to 9.76562e-14
    Changing Tseed to 0.00976562
    Changing Tseed to 9.76562e-15
    Convergence Failure: Time step too small; initial timepoint: trouble
    with node "u1:4"
    Simulation Failed: Iteration limit reached
    Total elapsed time: 24.299 seconds.
    Ich habe den time step oft variiert. Es gibt eigentlich keine offenen
    Leitungen. Verwende ich das Gate selber, z.b. so:
    Dann funktioniert das Gate. das komische ist aber, dass aus der
    Spannungsquelle -33 nA fließen und durch den Widerstand -8.3 mA fließen
    (warum minus?)
    Auch wenn ich an den Source Pin einen Widerstand ranmache, funktioniert
    das Simulieren nicht mehr:
    ">[​IMG]
    Vielleicht hat jemand nen tipp? Danke schonmal im Voraus!
    solver = Normal
    tnom = 27
    temp = 27
    method = trap
    noopiter" to skip.)
    Gmin = 10
    Gmin = 1.07374
    vernier = 0.5
    Gmin = 0.180144
    vernier = 0.25
    vernier = 0.125
    vernier = 0.0625
    vernier = 0.03125
    vernier = 0.015625
    Gmin = 0.180144
    vernier = 0.0078125
    Gmin = 0.179749
    Gmin = 0
    Transient analysis.
    with node "u1:4"
    ">[​IMG]
    (warum minus?)
    ">[​IMG]
    Vielleicht hat jemand nen tipp? Wäre für jede Hilfe sehr dankbar!!
Transistorschaltung Simulation in LT Spice - Ähnliche Themen
  1. Spannungen an Transistorschaltung
    Spannungen an Transistorschaltung: Hallo, kann mir jemand erklären, wie man die Spannungen an den Widerständen R1, R2, R3 berechnet. Die Zeichnung wurde in LTspice erstellt. Der...
  2. Frage zu einer einfachen Transistorschaltung
    Frage zu einer einfachen Transistorschaltung: Hallo, ich bin Tom und 13 Jahre alt. Ich bastle gern mit Transistoren und habe schon einen Wechselblinker und einen Detektor gebaut. Nun möchte...
  3. Transistorschaltung Schaltstrom 10 V für Ventilator 230 V
    Transistorschaltung Schaltstrom 10 V für Ventilator 230 V: Liebes Forum, Ich wüßte gerne, welchen Transistor ich für folgende Schaltung verwenden könnte: Ich möchte ein elektrisches Signal auf Netzspannung...
  4. Entwurf Transistorschaltung (Mosfet) für Magnetspule
    Entwurf Transistorschaltung (Mosfet) für Magnetspule: Hallo zusammen, ich muss im Rahmen meiner Bachelorthesis eine Ansteuerung für eine Magnetspule mit Labview entwerfen. Die Spule arbeitet mit zwei...
  5. Transistorschaltung (Problem)
    Transistorschaltung (Problem): Hallo, Da ich neu im Forum bin, hoffe ich einfach mal, dass mein Thema hir richtig ist. Ich bin zur Zeit dabei mir mit Hilfe eines Arduino UNO...
